Hey team,
Looking for some advice with a code I got thrown yesterday concerning the passenger restraint system
BMW 640D (66 plate)
For context:
Removed my glove compartment to access the FWD fuse board whilst investigating my right indicator issue I am currently experiencing
This involved me having to disconnect an audio chime plug and the airbag connection. Once I reassembled everything I am now getting the passenger restraint error
I am going to try and make sure I definitely connected it upon rebuild, however I am quietly confident I did
Anyone experienced the same thing? Have I made a back side of it? Am I supposed to disconnect the battery whilst doing this?
Any advice is greatly appreciated!
Kind regards
Morning John
Yes the battery should have been disconnected, with luck you could try disconnecting the battery (Neg first) for at least 30 mins (a dealer trick)to reset fault codes. If that doesn't clear it then you will need a good BMW friendly Diagnostic program to reset and clear the codes.
Good luck
Hi Dave,
Yeah Roger that mate, I figured as much!
I was sure I had done the clanky work correctly lol!
Thanks for the response mate, much appreciated 👍
    2. 6
    3. 14
    4. 13
      SLIPPING CLUTCH
    5. 13
      SLIPPING CLUTCH
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
