Hi Paul
If the self levelling warning is on then there is a fault probably with the self levelling sensor which will need checking/repairing/replacing.
Remember if the headlamp aim is out of alignment it is a fail anyway. If you check www.realoem.com put the last 7 digits of your Vin into the search box and look at the headlight section the small exploded drawing will help with location then check whether the sensor is stuck or the plug connection is in need of cleaning. If that doesn't clear your light then change the sensor the correct part number will be on realoem
PS Allfuses have been checked I hope
