Hi, my yellow engine man light is on. I know it's related to the EGR so it's not detrimental to the engine, but what causes it? It came on initially last year, so I had it cleared at my local garage, but it came on again a couple of miles after. Then it disappeared by itself last June but came on again today. Any help/advice gratefully received. Sorry, its a 2.0 diesel 175bhp, 2010 model in a 120d M-sport.
Morning John
What makes you so sure it is EGR related ?
If it is in fact EGR related the Complete EGR system needs cleaning and checking or replacing to ensure that it is working as it should. The DPF and its sensors also needs checking
If the Garage just diagnosed the fault and reset the code it hasn't fixed the issue
Hello John, below steps can helps you to out from the problem
Clear EGR Valve: Carbon buildup can hinder EGR Performance. Clean the EGR valve can help.
Check EGR Sensor: A faulty EGR sensor might trigger the light. A diagnostic scan can pinpoint this.
Inspect the leaks: Check for leaks or loose connections in the EGR system.
Software Update: Some models benefit from a software update to improve EGR function.
Replace EGR Valve/Sensor: If issues persist, consider replacing the EGR Valve or sensor.
Professional Diagnostic: A mechanic can perform detailed diagnostics to identify the exact cause.
      Noise
      Noise
      Misfire at 2000rpm
      Bmw 116d 2011 her fault codes
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
    • welshchy earned a badge
