M135i 2020 Boot/Trunk Badge Position
Misfire at 2000rpm
Hi John Welcome to the Forum I would check very carefully the loom to the coil packs and the Injectors. I have seen a misfire fault on a Volvo T5 and a BMW 335i neither car logged fault codes. Both cars would start and run smoothly and show no fault or misfire even when revs were raised, but if the car was under load the symptoms were there. The T5 it was injector harness with cracked insulation and the BMW failed insulation on the loom to the Coil Packs Hope this helps Dave -
2010 X1 Water leak on passenger side footwell
I have a 2010 x1 which has developed a water leak, when I wash the vehicle with a hose pipe, there is water in the footwell on the passenger side. Any ideas and or help would be appreciated. -
Bmw 116d 2011 her fault codes
My name 116d has a judder when accelerating, strong smell from exhaust and low mpg I plugged a diagnostic reader in and it came up with EGR codes, I have replaced my EGR valve, map sensor mafs sensor and breather hose but still experiencing the same issues plugged in reader again still says egr codes and then bank 1 lambda sensor so replaced that and still have the egr codes. any one have any idea what it could be as have sunk loads of money into it so far and don't want to keep doing so -
Misfire at 2000rpm
Hello, my 20 year old 3 series estate (E91) has 93,000 miles on the clock. There are no codes detected at a BMW specialist's garage but there is a slight but noticeable stutter on acceleration. It happens when the engine reaches 2000 rpm in all gears. The vanos solenoids have been replaced, a new fuel pump fitted, new ignition coils and spark plugs. All the injectors have been cleaned and tested. A smoke test for leaks has been done-none discovered. Can anyone think of any other checks that can be done without breaking the bank? -
X5 wanted
I have a 2003 for sale. email me if you like to chat. thank you John.
