A couple of weeks ago, on a particularly cold morning I got the 'Low oil pressure.... stop carefully etc' warning. My heart sank having spent a small fortune over the last couple of years on several major repairs. However, I turned the engine off and back on and the warning had gone. This has happened a couple more times and I went to a local BMW specialist. They couldn't find anything wrong but did say any repair if needed would entail lowering the subframe or engine out - 6 hours work. It's happened a few times since but only when the outside temperature is low and never when the engine is warm. The car has a full and complete service history, had £1000's spent on it, done 156k miles and is a 520D. Should I be worried?
Morning Paul
Always a worry when one of these warnings surfaces there is an Oil Pressure sensor normally on the Filter housing I would start there
If it hasn't been done recently Oil and Filter change and new sensor and see if that fixes it
Good Luck
      520d advice
    3. 13
      Fuel rail pressure problems.
      Would you buy this car?
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
