Hi all,
On a 2019 220d Active Tourer Xdrive, how do I reset the service indicator? Car isn't due for a service yet, but can it be reset without any extra equipment?
Regards
Eddy
Morning Eddie
Never played with a 220d but try
1. Turn on Ignition (press start button 3 times)
2. Press the button on the end of the left stalk for 10/15secs
3. You should now be in Service mode release the button and each press should scroll you through until you get to the service you want
4. When you find what you want press the button for 5/10 secs then release then repeat it should turn green
Personally I am not a fan of extended service intervals so change oils and filters annually (around 6k these days) Remember BMW also program in time dependent service Points. Brake Fluid, Inspections etc.
Hope it works for your motor
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
