Morning Elijah
Normal things, does the cars general condition match the mileage. What is the service history (check it if you can) Make sure everything works inside all the switches and gadgets (there are no cheap fixes) Mechanically the BMW straight six is a strong engine it should be smooth and vibration/knock free, Gearbox is ZF and should have been serviced also if not it will need doing.
Reading the add the guy sounds like a bit of a Trader so questions like is the title in his name may tell you more
