Hi, Any suggestions  removing the locking nut from the driveshaft so the drive shaft can be removed so i can replace the centre bearing, do i need a device to lock the driveshaft or is there any other way .
Morning Daren
I have used a long pry bar to lock and hold the Prop while loosening the lock nuts (last one I did they were incredibly tight) Jobs a bit of a faff until it is on the bench
