I have a 2011 118D E87 N47. The previous owner has installed an aftermarket Android head unit into the storage box on top of the dashboard. The head unit is a MEKEDE head unit from AliExpress. Here are the specs: https://i.imgur.com/WASjORM.jpeg
The center console armrest buttons work with the head unit, but the wheel controls don't. The wheel controls don't even work when I use the stock Business CD radio.
To get the music/sound from the head unit, I need to set the stock radio to "AUX".
The head unit also has a reverse camera, Bluetooth, and a microphone, which all work.
So how do I connect the wheel controls to the head unit? How do I know what type of cable to get, if that's what I should do? What other info can I provide here?
Any pointers and help is appreciated!
Morning IIija
Normally with aftermarket Head units there will be a Canbus interface that plugs in to allow all in car controls to work as normal
I would guess either the Canbus interface hasn't been fitted or is at fault have you tried contacting the Manufacturer to see if they can offer advice ? Installation manual for example that may give clues.
Good Luck
      Would you buy this car?
      2009 X5 E70 35D
    5. 0
      Knocking noise
    • Amk earned a badge
    • Glyn6653 earned a badge
    • John perr earned a badge
    • Martyn58 earned a badge
