Hi, I’m a new member and hope someone can name this part. I’ve tried online parts lists but am unable to name it correctly to get a hit.  I’d be grateful for any help.
Thanks, Jeff
Morning Jeffrey
I believe they call that a buffer stop BMW used them on several models so should not be that hard to find.
One of our Z3/4 drivers may be along to confirm
Hope this helps your search
I think Dave has hit the nail on the head with the name of this component
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2499334.m570.l1313&_nkw=bmw+z4+bonnet+buffer+stop&_sacat=131090
Thanks so much, Trevor & Dave.  Once I put in “Buffer Stop” on a parts site it immediately came up with the right gizmo!
Regards, Jeff
Glad it worked 😃 Try (if you aren't already) www.realoem.com for BMW parts numbers some times it takes a visual search of the sections as I don't think it would find Gizmo 🤣
    2. 6
    3. 14
    4. 13
      SLIPPING CLUTCH
    5. 13
      SLIPPING CLUTCH
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
