Failed turbo
2008/09 520d
Morning Martin Welcome to the Forum Try Disconnecting the Battery for at least 30 mins (a Dealer trick to clear faults) Neg first Dave -
16
Air bag fault
Morning Dimitri I believe if the oil is below safe levels it may prevent engine start and show an oil warning but if it isn't working !!! Unfortunately many Main Dealers (not just BMW) loose interest after their Warranty Responsibility ends. So unless a Diagnostic scan is called for and paid for they do not do them and even if they find something which doesn't have an effect on day to day running it gets ignored or for gotten. As I said my 4.6is I fitted 3 Oil level sensors before it was fixed. The car had a full BMW history when I scanned the car that fault was there when I asked the dealer they knew about it but pointed out the sensor can only sensibly be changed at the next Oil Service and the Dip Stick allows oil level checks. I also had an AUC sensor fault Dealer again was not concerned but for me if it's there it needs to be working. Enjoy your Beemer Dave -
16
Air bag fault
16
Air bag fault
Not unusual for the oil level sensor to fail but never heard of one stopping the engine starting, though it does sound logical I changed 3 on the 4.6is but you have to wait until Oil Change as they are in the bottom of the sump Dave
