Hope this has not been beaten to death already.
can I use20" x5 wheels on a 2015 650I X?
     thanks.
Morning Terry
Are they BMW OEM or After Market ?
If they are after market then check load capacity (I have read of cracking) and off set to clear callipers, you say 20" x 5 ? Is that studs I hope not width ? or are you looking for a spacer saver spare? If so don't forget the Jack and wheel brace (I know a few who have 😂)
If you aren't aware check www.realoem.com it is a BMW online parts website put the last 7 digits of your Vin into the search box then check the wheels/tyres section you will get all wheel sizes including off set
Hope this helps
Absolutely correct my E53 runs 9.5 x 20 Front and 10.5 x 20 Rear and the E70 is as yo say 10 x 20 Front 11 x 20 Rear. Not really necessary on a 4x4 but BMW Designers like the looks 🤣🤣 ( and so do I)
Hope you found what you needed
