I have a BMW 5 Auto Tourer Estate 2011.  Tick-over very erratic - almost cutting out and sometimes does cut out whilst idling at traffic lights etc.  Also I can hear a slight and constant hiss (not a whistle like a turbo fault).  Any ideas what could be the problem.  Many thanks.
Hi Allan
The fact you can hear a hiss sounds like either an air leak (inlet manifold) or a vacuum leak
Both will upset running a bit more information what engine diesel or petrol would help
I agree with Greydog.
have a look around the MAF sensor. A split between this and the engine block will give erratic air mixture.
also, check the battery voltage … my x5 sometimes starts rough idling and revving when it’s a bit low and throws a throttle position sensor fault at me.
      filter change recomendations
    • Graham J earned a badge
    • EonT earned a badge
    • delh1982 earned a badge
    • Norberg earned a badge
