![](https://static.aciresource.com/assets/disclosure/ebaydisclosure.jpg)
Bonnet release catch e53
Morning Stu Mole grips on the cable end has always worked for me Just asked an ex BMW Tech he says same part just the lever and mount are handed Dave -
Hi Dave, thanks as always! its definitely the unit that has failed. I broke the cable stop part off trying to frantically open the bonnet.. I’ll also replace the cable as that has seen better days. I’ll give quarry a try, no seller online seems to understand left and right? It can’t be the same part as it must fit mirror image. I don’t get on with my local dealership after they found my car had been written off and dodgy repaired and told me it was worthless…. They sold me it a month before (that’s another story) and gave it a 100,000 point check or something! anyways… I’ll be sorting it myself….. now to open the bonnet again!! -
E61 520D 2006 Drive Control System and other errors
Hi just thought I'd update my listing all my problems listed in this and in the pictures was due to an intermittent alternator regulator issue (over voltage) Cheers -
9
Mini one radio on/off button not working after car battery w
Hi, how did you fix it in the end? Was it costly? -
Morning Stu First is the mechanism actually broken or just the cable, I have seen quite a few and it normally its the cable not the mechanism. You should be ok changing just the cable I would think It seems looking at ISTA that the part is the same the lever and trim are different (opposite hand) All you have to do is stand on your head in the footwell to check 😂 If your still unsure ask someone like Quarry if they have the parts (I am sure they will) or even a BMW Dealer if your local one is friendly Dave
