![](https://static.aciresource.com/assets/disclosure/ebaydisclosure.jpg)
Bonnet release catch e53
Hi Stu Which bit have you broken 🤪 clumsy boy 🤣 Is it the manual bonnet release with the lever that comes forward through the grill or one of the bowden cable catches? I believe the manual release is the same (left or right) the Bowden Cable releases are the same part or could it be the Bowden cable arm in the footwell ? Dave -
Afternoon all.! silly question, but I have snapped the mounting plate for the bonnet release catch. looking online and realoem shows a part but it’s fitted on the lhd model, which would surely work back to front on the Uk spec RHD model? I can’t find another rhd part code or replacement part. am I missing something, or do both parts fit ? -
E38 735i Engine thermostat
Morning The car i did the upgrade on was a BMW X5 4.6is 2003 not a 7 series however the engine in your car should be an M62 V8 my 4.6is was also M62, just a larger version of your engine Dave
