2013 X3 F25 - timing chain issue
First time poster. I have 2013 X3 F25 2.0iD Xdrive. Off the road since last Friday with suspected timing chain/DPF/turbo failure. Looks like only option is to sell for parts. Any recommendations or other suggestions? TIA. -
218i ZF auto message oil needs service after 3 years i
My car is five years old with 20000 miles I now have a message that my transmission oil needs a service I have been told that this is a progmammed BMW message is this true? -
Bmw 1 series 2016 116i thermostat replacement
Thank you very much graydog. Will be checking it up on that and will let you know how I get on. -
Morning Asim Welcome to the Forum Good fun BMW's I have seen two types on 1 series engines 1. A sealed unit BMW called it a "Heat Management Module" mounts above the water pump front of the engine. Just make sure you use the correct coolant when swapping them. 2. Similar unit same location but the Thermostat could be changed again correct coolant is important Your engine should be B38 to check the Thermostat location take a look at www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model then search the Engine section. The small exploded drawings will help with location and correct Part Numbers Good Luck Dave
