I'm a new member.
I have an E91 330D Sport Touring (2009)  with active cruise control which I bought new.
The car is covered by BMW Insured Warranty. My Main Dealer cannot source a new part (ACC Radar Sensor 66 316777883) as BMW no longer make the Part.
Can anyone help me find a new or used part from a reputable supplier ?
Thank you in advance for any help/advice you can give ....
David
Hi David
How frustrating can they not adapt a sensor from a newer model they must still be able to get them as they still sell ACC systems?? You can check www.realoem.com if you are not aware put the last 7 digits of your Vin into the search box it will bring up your model then check the Distance systems section. If you double click the part number it will give any alternate part numbers that can be used and the models they were used in.
Not sure who makes the sensor if you can find out the manufacturers may help. There is a register of BMW Dismantlers I have used Quarry Motors several times for hard to source parts with great success
Finally there are companies such as ECU Testing and Cartronix who have been able to bring stuff back to life for me in the past.
Good Luck with the Hunt I hope this is of use
THANK YOU so much for the advice. I tried  looking for alternative part numbers on   www.realoem.com    and entered all my details and was doing fine until It asked me for my credit card details s ("no charge will be made now , during the free trial period").  I didn't understand what I was signing up for.... so didn't go any further
I Googled BMW dismantlers which produced a list my wife and I trawled through without success, I'm afraid
I've contacted BMW Customer services who were very helpful and promised to search themselves to see if they could unearth the part.
I'll  try ECU Testing and Cartronics this afternoon, thank you.
The car is in very good shape (only 74,000 miles) , full service history from our local main dealers since new and new BMW parts fitted under the BMW Insured Warranty over the years.
We are worried about how a lack of Cruise Control would affect the price if we were to sell it .....
David
Afternoon David
The Diagram attached is from realoem the list of part numbers corresponds to the diagram also attached below is the list of other models that used the part and the alternate numbers
Hope this helps
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
  For vehicles with
Active cruise control
S541A=Yes
01 ACC-Sensor   1     66316777883 $2341.37
02 Bracket f ACC   1     66316769132 $17.80
03 Bracket f ACC   1     66316769133 $6.43
04 Torx bolt ISA M6X18 SW 3     07146959923 $0.55
05 Adjustment equipment   3     66316762520 $1.90
06 Longitudinal dynamic module   1 09/2006   66316775949 $339.45
  For vehicles with
or
Dynamic cruise control
S541A=Yes
S544A=Yes
07 Body nut ST4,8-9-ZNS3 2     07129904150 $0.25
08 Hex head screw ST 4,8X19 2     07147154286 $1.16
10 Universal socket housing uncoded 18 POL. 1     61138364666 $0.68
  only in conjunction with
-- Contact bushing MQS with cable 0,5-0,75 MM² AG X     61130056960
-- Universal cover cap, uncoded 18 POL. 1     61138364662 $2.30
Realoem Alternate prt no's.docx
Hi David
Don't ignore 5, 6, 7 series models of around your cars age they all had ACC as an option as I recall
      filter change recomendations
    • Graham J earned a badge
    • EonT earned a badge
    • delh1982 earned a badge
    • Norberg earned a badge
