I own a 2000 323ci Convertible. The passenger seat is all the in the rear position and is not working. I have replaced the switch, and am getting power to the switch, but seat does not move. So, I am looking to replace the motor. Is there any way to manually move the seat forward so I can get to the rear seat bolts so to remove the passenger seat and get the motor replaced?
Any help with a step by step or advice would be appreciated
agoldsmith52
Morning Alan
I have done this job (or similar seat jammed) on a 5 series. The only way I could figure out was to raise the seat angle at the front the motor that controls front rear movement was on the transmission tunnel side of the seat. The two bolts that hold the motor to the frame can be undone and the motor wriggled back to disengage the drive gear, the seat was then free to move so it could be taken out. Getting under the seat to release the motor was a real faff and high on the cuss list. Don't forget as soon as the seat is raised as high as you can get disconnect the battery to avoid any airbag issues. It goes without saying the job is easy peasy with the seat out.
If you aren't aware use www.realoem.com to get the correct part number for replacement, if you have any issues let us know.
