Morning Iain
Simple job swapping the stop/start button should take max 5 minutes. Prize out the existing button using a trim removal tool or a small flat screw driver with some insulation tape stuck on the blade to avoid scratches to surrounding trim. lift the button out and release the plug at the rear plug in the replacement and push it home. Job done
Good Luck
