Can anyone help,I have bought a couple of hoses and they don't fit,mine has the extra little hose that fits onto the air box small pipe on bottom,the ones I keep getting sent to me have either not got the small pipe on bottom or it does but slightly to long,I can't find the correct one anywhere
I'm going crazy,
Morning Steven
I take it these are Crankcase ventilation hoses ? Have you looked at www.realoem.com put the last 7  digits of your Vin into the search box it should call up your model (Z3 should be in the Classic section) then search the Engine, Fuel  sections for what you need. Once you find the hose on the exploded drawings get the part number and you should then get the correct part.
Hope this helps
Hi Dave thanks for that,seen on a few other posts that the part number is wrong and just shows up the hose with out the bottom bit to air hose,seems that not alot of them had the extra bit to air box,but the 2.2i m54 does
Will give it a shot on that site thanks
Part number must be wrong as I put my vin in and comes up with the hose but not the correct one as I have a hose on the bottom also,someone else had this problem and said there was a problem with the part number and even at the bmw dealership parts people didn't know about the hose that had the small hose on bottom
No just the same as any z3 one but has the small hose on the bottom to fit to an extra bit on the air box
Yea so looks like that but at the bottom has an extra pipe,will steal a pic from another forum
I have ordered a hose will let you know how I get on,can't find the picture on other forum,but it's the same as the one u posted but has an extra hole at bottom going on the airbbox
      filter change recomendations
    • Graham J earned a badge
    • EonT earned a badge
    • delh1982 earned a badge
    • Norberg earned a badge
