Can you get into E 93 convertible boot through back of rear seat.
Hi Edward
Never had this issue to dealwith but I did read on one of the US Forums some time ago where someone had exactly the  same issue battery disconnected and boor accidently closed.
The solution is to apply 12V+ to Pin #12 of X14270 at the Junction box connector (Grey Green wire) this will operate the latch only. It is safe even if the Positive battery terminal IS in contact with ground, as power is ONLY applied directly to the latch, and NOT to the B+ terminal. Of course you have to ground your external 12V or 9V power source to chassis. The poster from memory didnt release the connector (which should be the large 47 pin one) he located the Grey/green wire and stuck a pin through the insulation then touched an external battery live to the pin with earth to the cars chassis.
Hope this helps
Hi. Dave. Thank you for info. However looked in electric box on bulk head but cannot find a Grey / geen wire. Do you know where l can get a wiring diagram for my car incase colours have changed
