 I am trying to "register" my satellite receiver bought on e-bay, The wiring harness Coax and power were stuffed into left side of trunk. All connected!
Any help would be appreciated.
Morning Ronald
First not sure which part your talking about here? In the UK/Europe the Sat Nav is integrated into the CCC/CiC sytem located in the centre dash.
What is the part number on the Part you purchased that may help
Morning Ron
So it is the Sat Radio unit try looking on www.realoem.com put the last 7 digits of your cars Vin into the search box
That should call up your model then search the Audio Nav section the small exploded drawings will show what should be there and what is connected to it you can also get the correct part numbers (double click the part numbers and it should show a list of alternates if available). Also worth checking the fuses in case someone pulled a fuse
Good Luck with the party plans 😅
Hi Ron
I spoke with a friend in BMW he says it will need a Diagnostic program like INPA/ISTA that has the capability to re-register the unit. He obviously favours BMW's program but I know others are capable of re-registering components he doesn't think you should need a one time code.
If you have a Diagnostic and can find the unit try reading the unit Data and look for the chassis number if the one that is there doesn't match yours wipe it and enter yours.
Good Luck
      Tyres for front of my 240i
    5. 0
      520d advice
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
