'07 BMW 530i junkyard satellite
ronmayeur
Morning Ron
So it is the Sat Radio unit try looking on www.realoem.com put the last 7 digits of your cars Vin into the search box
That should call up your model then search the Audio Nav section the small exploded drawings will show what should be there and what is connected to it you can also get the correct part numbers (double click the part numbers and it should show a list of alternates if available). Also worth checking the fuses in case someone pulled a fuse
Good Luck with the party plans 😅
    2. 5
    3. 5
    4. 9
      A paddling pool in the rear of my 08 reg 635d Convertible !!
    5. 5
    • Poohbear1962 earned a badge
    • Mannyc earned a badge
    • Sherbuttgate went up a rank
    • Sherbuttgate earned a badge
    • ronmayeur went up a rank
