Largest size you can fit please on 2009 318d LCI currently running 225/45/17 Run Flats all round, looking to go wider on rear but not sure how wide i can go.
Morning Pat
If you are keeping the original wheels I believe BMW offered 255x40x17 as an option. You can check www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model then check the Wheels/Tyres section you should see a list of all wheel/tyre sizes offered OEM
Hope this helps
      Newbie here
    2. 4
    3. 13
      Newbie here
      Appears no fire
    • nickl81809 earned a badge
    • Mark lingham earned a badge
    • Benny Brown earned a badge
    • Paul M earned a badge
    • Drumj earned a badge
