Morning Roland
As far as I am aware as long as the battery fits dimensionally and is the correct capacity it only needs registering  to ensure correct charging.
You can check on www.realoem.com just put the last 7 digits of your Vin into the search box then check Electrical Section from memory AGM batteries were a standard fitting
Thank you Dave the dimensions are critical as you say as we had to measure the box in sits in
best wishes Merry Christmas.    Roly 🍷🍷😎
    5. 12
    • Aaronelvis earned a badge
    • Bubba jay earned a badge
