Hi all
  Newbie on here, I was wondering if anyone can help me out, I own a 2012 e70 4.0 the other day my Mrs started it up & the dash gave out a transmission failure reading,she couldn't get any gears or knock it out of park. I started it up next day & nothing showed up & it drove ok, i know a mechanic & he ran a diagnostic report on it, it flagged up with the code 00A82E Gws(gear selector switch) interlock E faulty. He said to chat to you guys first to see if there's a cheaper option than going to main dealer ?? Loving it bits apart from this, really appreciate any help 🙏
Hi Shaun
I have read several times about this problem though not seen/suffered one myself
From what I read the only solution is change the unit two choices, first BMW I have read £1k+ quotes and long wait times for parts. Second choice a used replacement first use www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model get the Part Number for your car, double click the part number and it should show a list of any alternatives if they are available. Then Google to find the part and check prices Apparently it isn't a major issue to swap a DIY job then get your Mech friend to clear and reset codes
Good luck
      520d advice
    2. 13
      Fuel rail pressure problems.
    3. 2
      Would you buy this car?
      Selling a BMW wall charger
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
    • Amk earned a badge
