Never experienced this before but the rear view mirror has seemingly parted company from the windscreen. It seems that a round metal disk should be glued in some way to the windscreen and then the plastic housing can be put back. Any experience/instruction out there on how best to go about reattaching this?
Morning Paul
I believe you can also get an adhesive to stick it back, goes without saying the screen and disc have to be really clean and dry
On 1/24/2025 at 7:11 AM, Greydog said:
Morning Paul
Ill research the adhesive thanks Dave. Yes, to the clean surfaces.
Morning Paul
The sensor sticks back same as the Mirror just make sure everything is clean it goes without saying the sensor has to have a clean view of the screen, no sticky pad in the way 🤣 or your lights and wipers will think they need to be permanently on 🤣
      SLIPPING CLUTCH
    2. 6
      Winter driver's door problem
    3. 6
    4. 6
      318 se 06 no fan moter
    • Daniel8347 earned a badge
      Reacting Well
    • PresWalk earned a badge
    • tonyrad earned a badge
    • CGH earned a badge
