F30 satnav and software upgrade
SLIPPING CLUTCH
Hi Dave, not had a great January so far health wise including a week in hospital but back on the mend hopefully now. I'm trying to catch up on a few repairs due to the heavy storms sot got anything done about Ista/inpa but will keep you posted when i get moving. cheers Paneuro -
Winter driver's door problem
Hi Daniel The only electrical connection is the under handle LED on the outside door handle. The door handle has a Bowden cable that connects it to the actuator, the actuator has electrical connections to communicate with the cars control system the actuator is bolted inside the door, the inside door handle is also connected to the actuator by a second Bowden cable To work on it you will have to take off the inner door card then carefully peel away the water membrane. Once the actuator is exposed you can get your hand behind it and unhook the Bowden cable then remove the outer handle and unhook the other end of the cable. Fitting the new cable is obviously the reverse Dave- 1
Do you mean these metal cable or is there maybe some other electric wire there -
Hi Daniel The door has an electric actuator for locking/unlocking the outer handle is connected to it by a cable if the outer cable is sticking the actuator can't release so the inner handle will not work. The only fix I think will be a new cable to the outer handle Dave -
318 se 06 no fan moter
Morning Tony Welcome to the Forum All fuses check OK ? If you are a DIY man then in the passenger footwell behind the covers you will find the Blower motor housing. Fixed to the bottom of the fan will be the Fan Regulator (Sometimes reffered to as the FSR) This is quite often the problem, though the blower unit itself can be changed I would expect a Regulator to cost around £20 to £30 a complete fan around £60 to £90 Good luck Dave
