8
Drop the driver side speaker cover and speaker in the roof and you see the existing loom that goes to / through the boot hinge -
Hello everyone, got a 116i m sport n43b20a. Had it for about 3 months and soon after buying noticed a wierd problem. When cold the car would run perfectly, however when warm or stuck in traffic you could feel it become a little bit rough, sort of a banging feel from the engine which you can feel through the car. When doing this, when driving it runs perfectly. However when you attempt to pull away, the car will drop to around 400rpm and pull away a bit bouncy, having to give it more accelerator to prevent it from stalling, whenever in reverse it does this and normally leads to stalling. Over the last 3 months it hasn’t gotten worse but it does the pulling away thing when it is cold now. Had a service >1k miles ago with plugs. Also had it smoke tested and no signs of any leaks. Does anyone have any advice or had a similar story? Cars on 161k Thanks -
2008 E61 start issue
Looking for some help. 2008 BMW E61. 520d Car died and wouldn’t restart. Issue looks to be throttle body however have replaced that and same issue just cranks. Battery went flat with all the cranking and checking around. then worked and started after charging. Drove 20 miles or so. Thought all fixed, next morning. Started and died like before. Now won’t start. But if throttle body is unplugged it’s starts and drives. HELP
