Morning Steve I have never worked on a 2 series but would imagine like the X3 and X5 internal trims around the rear window have to come off for access or maybe like the X5 the spoiler top fixings can be accessed from outside I would check www.realoem.com to see how the trim parts are fitted -
Morning Paul You have one major answer, your Local Main Dealer is not a good one !! Have you talked to BMW UK Customer services ? Clearly either the Dealer doesn't have a clue or there is an issue they also don't understand ? Worse by telling you a road test would be dangerous are they saying the car is in a dangerous condition ? All questions I would put to BMW UK Good Luck Dave -
Morning Billy You need a diagnostic session to narrow things down, at 161k I would also carry out a compression test and check fuel delivery and pressure. Your symptoms could be an accumulation of things or as simple as a dying throttle body diagnostics will help Dave
