2011 116d E87, N47
The issue I am experiencing is the airbag light is off when driver only is belted in the car. When a passenger sits and / or is belted in the car the airbag light comes on with the seat belt sign. When the passenger exits the car and the ignition is turned off and back on again the airbag light is off. The airbag light only comes on when the passenger sits in the car.
No codes are stored when the airbag light is off. the fault code 93C2 - SBE seat mat is stored when the airbag light is on.
I have tried installing BMW E87 Seat Occupancy Sensor Bypass Mat Emulator Simulator, however all this does when plugged in ses off the airbag light when the ignition is on, and no one is in the passenger seat. I am unable to erase the fault code when this item is plugged in. Uninstalling it, and reconnecting the original wiring, allows me to clear the code, and ab back to the same scenario.
I thought that once the airbag fault is triggered, thw warning light stays on until the fault code is erased. What I experience is that the warning is only present when a passenger is in the front seat.
Any ideas on how to resolve this.
Hi. You have diagnosed the issue correctly.
its the occupancy sensor in the passenger seat.
possible it is a broken wire in the seat giving a high resistance which is why it’s reading faulty with the bypass switch?
Stupid question, but is the airbag switched off? This would cause there symptoms?
      The E70 is misbehaving again !!
      Airbag Warning light - Strange Intermittent fault
    4. 0
      Camshaft stuck issues
    5. 0
      Steering wheel controls - 2012 1 series
    • Ian68 earned a badge
    • Dipul earned a badge
    • GriffinBoy earned a badge
    • Kokejn earned a badge
    • THFc61 earned a badge
