Hi all. E53 2002 has decided to throw a tantrum again.
firstly, the intermittent wiper has stopped wiping… all other settings are fine.
secondly, the headlight symbol has disappeared from the dash… the blue full beam one comes on when active, but not the normal or dipped one.
All external lights are fine and working correctly.
Morning Stu
The fact you have a wiper issue would point me away from the Cluster initially
My thoughts are Footwell Module it's in the left hand footwell (well it would be 😅) Run a scan it should show up any issues. The Footwell control module on the 4.6 caused all sorts of odd stuff radio that would randomly turn on/off odd light issues seat controls. BMW say you can't swap them it has to be new and set up by them (wrong of course) I changed mine for an upgraded unit second hand it took longer to remove the old unit and swap it than it did to re-program it cured everything and probably stuff I hadn't found 😅
P.S I wont let the E70 on Whats App or Face Book just in case 🤣
      My new E64 650i
      2009 X5 E70 35D
    4. 5
    5. 0
      Would you buy this car?
    • Amk earned a badge
    • Glyn6653 earned a badge
    • John perr earned a badge
    • Martyn58 earned a badge
