My name 116d has a judder when accelerating, strong smell from exhaust and low mpg  I plugged a diagnostic reader in and it came up with EGR codes, I have replaced my EGR valve, map sensor mafs sensor and breather hose but still experiencing the same issues plugged in reader again still says egr codes and then bank 1 lambda sensor so replaced that and still have the egr codes. any one have any idea what it could be as have sunk loads of money into it so far and don't want to keep doing so
Hi Chynna
What Diagnostic Reader did you use although many readers will give a code they will be general rather than specific
A BMW capable Diagnostic reader will normally not just give a code it will also give a description of the fault helping in diagnosing a fault
      Misfire at 2000rpm
      Bmw 116d 2011 her fault codes
    3. 4
      Misfire at 2000rpm
      Noise
      Noise
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
