My 116 has developed a judder under idle like a injection fault but I've had it on a scan tool no faults found anybody got any ideas
Morning Spblade
A rough idle can be caused by a number of things from an Air leak to as you say an injector issue. Is it 116i or 116d makes a difference in diagnosis If the scan tool was a generic tool it will miss a lot you really need a BMW specific tool
How many miles has it covered when was it last serviced (not just an oil change)
3 hours ago, Greydog said:
Morning Spblade
Hi dave it's a diesel car was serviced not long ago had new box as reverse gear  went, clutch was new at same time car done 101.000 scan tool was a snap on I think .
Hi
OK 101k is no great mileage so I would start by checking for any Air or Vacuum leaks on the inlet side initially. I would also check carefully the injector loom for any damge or cracking to the insulation. Go on line and get the test procedure for Injector loom and Injectors (test for resistance) Have the engine mounts been checked ?
Snapon is normally OK but it depends on the model some older ones revert to Generic codes
19 minutes ago, Greydog said:
Hi
It's quite a new one not checked engine mounts will do later when I get home this weekend and have a look at wiring but if fault with wiring it would have thrown on emg light
      engine judder while idle
    2. 4
    3. 4
      Battery Restraint Malfunction / Battery change
      Remapping
    • spblade earned a badge
    • Paul76 earned a badge
    • MLathan earned a badge
    • IanMc earned a badge
