Hi, I'm new here. Thanks in advance if you can help!
I just bought a S/H X5. 2002. 3.0 petrol. 120k miles.
It's as sweet as a nut but there's a weird noise coming from the top end.
It's intermittent. Seems to go away when the engine is hot.
But alarming! Any comments would be much appreciated!
Thanks, Norm
Hi Norm
Sounds like a Tensioner needs replacing possibly water pump but the tensioners are the place I would start
That’s a noisy bearing or tensioner as greydog said. Try different things like turn the AC on and off to see if there is any difference. Hopefully an easy one.!
welcome to the petrol X5 world!
Hi Stu and Dave, great info, thanks to both!
As an update, what's odd is that when the engine is up to temp, it's totally silent.
Nothing. But when cold, it appears to be coming from under what I would describe as the spark plug cover.
I guess I should remove it? Take a look?
Hi guys, turned out it was the 'Idler Pulley' in the belt.
Local autoshop figured it out. $100 repair.
Thanks again for your help, appreciated!
Norm.
  • Like 2
      520d advice
    2. 13
      Fuel rail pressure problems.
    3. 2
      Would you buy this car?
      Selling a BMW wall charger
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
    • Amk earned a badge
