Vibration while ideling
Drivers side wiper not flush
Hey, Just seeing whether there is a common problem or if someone has an easy fix? My drivers windscreen wiper doesn't sit flush to the screen when moving, leaving patches on the glass. I have replaced the wiper blade, and had a go at bending the arm, but the problem still remains. Any hints or tips would be great appreciated. -
Weird X5 Top End Noise
Hi guys, turned out it was the 'Idler Pulley' in the belt. Local autoshop figured it out. $100 repair. Thanks again for your help, appreciated! Norm. -
5
Engine Failed with broken timing chain
Is there Any way of making the useless heads lights better apart from fitting high output bulbs ? -
5
It's now 4 years down the line and the engine was rebuilt by a local BMW wise kid. Has been running fine now that the Cats been muted and the ECU told that the cat ran off , runs better with more mpg and now on 109K miles. -
Air bag fault
Good morning Dave Thank you for your response. I did have some work done but none was in the steering wheel or instrument cluster. I do have an airbag code 09 "Side airbag, front right" on that I have not managed to clear out yet. I did clear the fault codes 2-3 times which it did remove most of the fault codes apart from 3, 09 Side air bag, front right 28 thermal sensor for oillevel defect - BTW my vehicle does not have a oil thermal sensor 94 LED for anti-theft alarm system open circuit - BTW the red light that is on the top of the dash has never been ON. Dimitri
