Hi I have a couple of problems with my 2009 x5 xdrive. 3.0d  first of all. Should I be able to select neutral with the ignition on with engine but not started. Secondly, since I’ve been unable to select different gears or neutral I cannot get my car to start. I’ve changed fuel pump relay as not getting any fuel to fuel rail. Are used to be able to select a neutral with the engine off with this now stop the car starting
      Newbie here
      Appears no fire
      Appears no fire
    4. 12
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
    • Aaronelvis earned a badge
