  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
HI all, is there a recommended change out period for air filter and Pollen filters on the 6 series, E64. Currently air filter and cabin pollen filters are 2023.  Any advice or thoughts gratefully received. Car does about 3.5K miles per annum.
Hi Paul
I would check the Cabin Filters mine on the E70 were damp and as a result smelly. Air Filter should be fine with a hoover as the miles are so low
My Milage is higher than yours between 4 to 6k so I oil and filter change annually
OK will look to adopt that advice. Oil filter does get changed out annually but will look to the air filter also. Good idea on hoovering the pollen filters though.
