Hi , Living in Lawrence Otago and need some help. I have some condensation forming in Lefthand headlight. I open the top circular seal and it eventually appears dry. But!  Now giving me fault codes on dash display. Like the auto adjust not working and other intermittent faults.
Is there anyone nearby that can assist with diagnostic or suggest a 'tame' service centre close to me? I have ordered  a control module but thinking about it I would hate to insert the unit when there may be other issues causing the problem and as a consequence stuff up the new module.
Hi Les
As this is a UK based site we may not have to many members near you
A Diagnostc Scan may help to tell you more, or maybe an Automotive Electrician can advise
You could check all the earth points BMW love mutiple earth points and earth switching
      filter change recomendations
      BMW 116i Hatch F20 2013. Headlight Issue
      2024 x6 six cylinder vs 8 cylinder. Is 8 Cylinder worth it
    • First Bima earned a badge
    • Rob Lee earned a badge
    • Sonnyj earned a badge
    • frankolinno earned a badge
