angel eyes
Misfire at 2000rpm
Noise
Noise
Misfire at 2000rpm
Bmw 116d 2011 her fault codes
Hi Chynna Welcome to the Forum What Diagnostic Reader did you use although many readers will give a code they will be general rather than specific A BMW capable Diagnostic reader will normally not just give a code it will also give a description of the fault helping in diagnosing a fault Dave
