epic BMW build!!
Hi Mishal Welcome to the Forum Check using www.realoem.com put the laST 7 digits of your Vin into the search box it will call up your model then check the relevant section. When you find the part number you need double click it and you will see a list of any other Part numbers and Models that they were used in. If you google the part numbers you should find compatible aftermarket Kits Dave m -
Hi, I am reaching out to inquire about a specific matter regarding flywheel parts for my vehicle. I have been investigating the following flywheel part numbers and would like to determine if they are compatible for the same flywheel: 1. 8681723 2. 8690203 3. 9454556 From my research, I found that part number 1 is applicable for vehicles manufactured from 2016 to early 2017. In contrast, part numbers 2 and 3 are meant for vehicles produced from July 2017 onwards. My vehicle, a 2017 BMW F30 330e (RWD, 1998cc, 185KW, 252HP B48B20A), falls under part number 1, as it was manufactured in April 2017. Given that these models are closely related, I am curious if the later part numbers (2 and 3) could also function in my vehicle. In the UK, I have been unable to locate aftermarket part number 1 at a reasonable price, but options for part numbers 2 and 3 are abundant. I would greatly appreciate any guidance or clarification anyone can provide on this matter. Thank you for your assistance. -
Sat/nav 8.8 screen upgrade
I have a F30 20ltr 2013 and want to fit the 8.8 display my car has the alpine radio part number 9323784 and I have the 8.8 display part number 9292248 and alpine number AL3008 0289 bmw L7 CID HIGH that I want to fit and I want to know if it’s compatible and need coding I have the ESYS ENET software for coding -
Air bag fault
Hello all, on the topic of the failure code 28 "oil thermal sensor oil level defect", considering this is an early vehicle that does not have an oil thermal sensor, and I do not have a fault on the dash, is the fault above an oil level fault and not an oil thermal sensor? I have read that if the oil level sensor fails the car will not start. is this true? Many thanks all for the great support!! Dimitri -
Yep I agree re the dealer, the pain is I've been looking at getting the wheels refurbed, just haven't settled on a place. I suppose if I get a new wheel the others can be matched to it or near enough. I will make sure the alignment is checked as well. As u say that's what insurance is for. The day was going too well! Dave
