They usually melt when the coil pack has a constant 12v and earth. One side of the coil pack should have a constant 12v + and the other side will be pulsed earth by the ECU. Usually when they melt 12v + and - are constant due to a short. Make sure that the wiring from the ECU to the coil hasn't been trapped or is shorting to the engine.
copied from another forum :rolleyes:
      520d advice
    3. 13
      Fuel rail pressure problems.
      Would you buy this car?
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
