aintree new mini show ''best mini cooper''
Z3 airbag wiring,
Hey everyone, I’m thinking about buying a 2021 BMW X3 and want to make sure I’m covering all my bases before making a decision. I’ve heard about VIN decoders and how they can give you details about a car, but I’m not sure what kind of info they actually provide. Do they show anything useful, like accident history or open recalls? Or are they just for basic specs? If you’ve used one that worked well, I’d love to hear about it and any tips for getting the most out of it. Thanks so much! -
Z3 airbag wiring,
Hi, Yes The air bag light is on. I have not heard of an emulator? It must be a device to turn the light off? The person that owned this before me was an older lady but maybe she had a mechanic do something to this? Thanks for your help, JayMe
