Face to Name : Facebook
- bmw 3 series
(and 4 more)
- bmw 3 series
(and 4 more)
14
SLIPPING CLUTCH
Morning Andrew I normally disconnect the Neg lead only, some folks disconnect both a few even say disconnect both and touch them together. Goes without saying both sensor plugs need to be checked and a squirt of contact cleaner applied never hurts 😅 Dave
