I was looking at these wheels,
Whats the biggest I can go? 19 inch?
And what tyres will I need to put on them?
id imagine they fit fine with a 235 35 tyre?
would you be lowering as well as itl look like its most likely on stilts, a nice 30mm drop really looks good
im planning on a 30 are 40mm drop on mine one day B)
I wasnt thinking of lowering, I worked out here that 19 wheels with 35 tyres would only be 5mm smaller than what I got right now so it should look ok
19's with a 45 should be fine (and much easier on the wallet when you need to change the rubber)
Could I get these on? EBay If so what tyre?
I imagine there wider than my standard ones, not sure about the offsets.
Also I've heard you need 4 front M3 wheels to fit the E46 because the offset differs at the rear????
theres a 7" wheel on the front and an 8" wheel on the back offset is the same as far as I beleive
Great stuff cheers mate
  • 1 year later...
just purchases some wheels m3 for e46
& the offset is different on rear rubs when going over bumps :(
