there may be more screws, some will most likly be hidden behind bits of plastic trim
once there all out you usually need a good pull to get it off, sometimes the panel may need pulling up slightly to.
just take your time
      Misfire at 2000rpm
      Noise
      Noise
      Misfire at 2000rpm
      Bmw 116d 2011 her fault codes
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
    • welshchy earned a badge
