Continental Headlights
Nothing at my injectors
Morning Bruce Welcome to the Forum and Happy New Year You need a Scan using a good BMW capable diagnostic system. Your issue could be Crankshaft or Camshaft sensor related or High Pressure fuel pump/sensor related. If you have continuity on the Injector loom then it should be OK. I have seen two that had single injector issues due to frayed brokn wires (badly fitted loom) but cars still ran fine apart from a misfire and lack of power. Both were fixed with a new loom from BMW Hope this helps Dave -
27
SLIPPING CLUTCH
Thanks Dave, I will have to find somebody to download and install it for me as its a bit beyond my capabilities. I will keep ypu posted on the progress. Happy new year Paneuro. -
Hi, new to this group i have a 320d efficiency and over the holidays I have had issues, firstly my orange battery light saying discharging whist stationary, then it developed a misfire I know it's a diesel but that's what it felt like, anyway thought I'd take it to work has im an auto electrician. On the way there I broke down. Once check for codes something regarding start ability, tried some easy start car runs with easy start, checked fuel at fuel rail all good. I have no lives or earth's at the injectors there is no fuse wiring is about 30 inches from the ecu straight to injectors. Any ideas? T.I.A Bruce -
M135i
Morning Gary Happy New Year and Welcome to the Forum A friend of one of our sons had exactly the same issue (2020 model) he contacted his Dealer who told him No can't be done a second Dealer also said Factory Fit only. He found a company online who fitted one for him and it works really well,(I just text him for details) The company is www.autologics.co.uk he said cost was £600 all in. I have no experience of them but he is a happy bunny 😁 Hope this helps good luck Dave P.S. My daughter says you don't need a camera you have acoustic sensors backed up by a THUD when to close -
6
Instrument cluster suddenly died
Morning Christopher Information for your Auto Electrician According to BMW the batteries are soldered to the Instrument cluster PCB As I recall Kristians fault was more power overload and we dont know if he was able to cure it Happy New Dave
