Hello all, I joined a while ago but haven't been on here yet so thought I'd pop in, say hi and have a browse.
I have a standard 318i se 52 plate, only mod is a private plate and owned it nearly 18 months. Its a bit poorly at the mo so hoping to find an answer :)
Caz
Thanks fella's, nothing major, he's had the airbag light on for a few months now but have been told its a common fault or also that it means the lambor senor is faulty. Not sure which is right. The rear offside light cluster has a melted connector and the dash 'light out' light keeps going on and off, oil leak and sometimes when cold I go to pull away at a junction and it just coughs and splutters till it either stalls or picks up again. Restarts no probs tho.. this is prob the worst fault as not good if you try and jump into a sneaky gap!!
Will book it in for a service and get oil leak sorted as guessing its a gasket. Other than that he's good :)
Welcome Caz :D
Have got a few niggeling bits needing sorting too. :(
Hope it all works out ok and not too expensive.
    5. 2
