Word Association Game
No emergency door lock
Hi my Battery is flat, my fob does not work. Removed caps at the side of the door handles, no emergency keyholes/locks present. I do have the fob keys, but no lock to put them in. BMW 420d 2014 Any ideas how to get in the car? Any help appreciated Thank you -
6
Morning Alexander Welcome to the Forum Paul used Liquid Moly additive I beleive, do remember that if the seals are hardening through age this will work if the seals have gone it can't do much Dave -
Bmw x4 2015 angel eyes
Morning Ben Welcome to the Forum Never actually seen this but from what I read it is normally the Halo LED's failing and needing replacement Dave -
Steering lock query
Morning Mike Welcome to the Forum Sadly we do live in times where extra protection is needed The good old Stop Lock is an excellent visual deterent. Whether the investment in a ghost immobiliser as well is worth the money no one can say untill it is needed. Personally the Stop Lock would be my choice (I use one when we are away from home) Dave- 1
