Ill give £20 to the last person to post on this thread
Hello
Hello, My name is David and I am the owner of a new to me x4m in sophistico grey! i love the car, i changed from a silverstone ii f80 m4. I miss my m4, but fair to say the x4m is a fantastic all rounder. Except it’s sooo quiet. Any tips on exhaust mods. I see a lot on other forums but mostly from users in the USA who don’t have the dreaded OPF filters. Not sure a res-delete would have the gains I am after; and not sure I want to code and remove the OPF given warranty concerns? tips welcome. Photos attached 😉 -
From E83 to F25
The spigot is the raised ring on the wheel hub that locates the wheel. It should match the big centre hole in the middle of the wheel, If the one in the wheel is smaller it wont fit if it's larger thewheel wont centre correctly and will probaly wobble Good Luck Buddy -
BMW climate control issues
Hi, Thank you Dave, yes it does help appreciate it, will check the fuses first of all, Gemma -
From E83 to F25
Thanks mate I will Deffs check that site out. Appreciate. God knows what a spigot is hahaha -
From E83 to F25
Hi Ian Welcome to the Forum Check www.realoem.com put the last 7 digits of your Vin into the search box (one car at a time) then check the wheels section. Check the wheel szes for both cars and the wheel Offset so you know they clear Brake Calipers The only other thing is check the spigot ring measure ment on both wheels Hope this Helps Dave
